engine runs on choke but not run?
Nissinator1996
my briggs and stratton engine will only run in the choke posistion and i have to pour some gas into the carb to get it running. if i try it in run it wont start at all and if i try it in half choke it still doesnt start....any ideas?
r97
Measure twice cut once
Massachusetts, USA
Sounds like it is running lean. I would guess you have either a bad gasket between the carburetor and head. Another possible scenario (would explain having to pour gas into the carburetor before starting) is an obstruction somewhere between the main jet and the fuel tank.
Check for a bad gasket by spraying carburetor cleaner around the intake gasket(s) while the engine is running. If the engine revs up while doing this you have probably found your problem, and you can then replace the gasket(s).
If the problem is a blockage somewhere there are a few common places to check/clean.
-fuel filters
-fuel lines
-diaphragm (if equipped)
-carburetor jet, bowl, and fuel passages.
Hope that helps
Nissinator1996
when i pour some gas directly into the carb to get it running(cold start) it leaks right out the bottom of the carb
