Engine Runs but Kart Does NOT!
Cstivers
The engine starts perfectly and runs very well, but when you push the gas pedal the kart does not move. It rocks a little bit, but does not move much at all. After several second of gas applied, the engine smokes a little but from beneath the cover on the torque converter and drive chain! Not sure what the problem is here but need it fixed! Any suggestions?
KartFab
Dallas, TX
Ok in addition to what felineman said you are going to have to go through your torque converter step by step and clean it out.
It has rust in it, a wire wheel/brush and or fine sand paper will do the job.
Your driven unit cam has moved past the wear tab and will not allow the torque converter to change ratios as the engine revs up (equivalent to driving a stick shift in 1st gear, no matter how much you step on the gas it wont go fast).
You will have to remove the drive unit and clean it out. There is a sticky titled "how to clean your torque converter" somewhere on the board, just look it up and follow the instructions.
PLUS
do a proper maintenance on the Torque converter.. with sheaves rusted like that you'll ruin the new belt within just a few minutes again.
[EDIT]
:oops:
too late again.. do as gran_pann said :D
