engine question.
pblr89
i am picking up my first gokart within the week and i plan on making it more of a project than my wife could hope for. the kart im picking up has a 5.5 honda engine. i have a 19hp Briggs & Stratton engine aswell from a riding lawnmower. my question is (seems obvious but maybe im wrong) isnt the 19hp way faster assuming same gear ration setup?
pblr89
so HP doesnt increase the speed at all? just the time it takes to reach max speed and both engines go about the same top speed?
ghostdog
Not necessarily. The rpm is not going any faster so how can it possibly turn the wheels any faster?
If your cart is really heavy then a low hp motor will not let you get to the top speed. You could put a 6.5 hp motor on a mini bike and on a go kart with the same gear ratio, both will end up at about the same top speed. The mini bike will get there faster of course.
Jcotz
...wasn't there
NY
Is the engine a vertical shaft? because if it is it is pretty much unusable for your purposes. Also, to answer your question, with the extra hp, you will be able to put it in a steeper gear ratio and still have acceleration.
ghostdog
Unless you are planning on making a super heavy kart to take advantage of the horsepower I would say you would save yourself a lot of trouble just getting a $100 harbor freight 6.5hp motor after coupon.
I agree.
Also, the only way that the 19HP motor will give you a faster speed is if you gear it differently. You can have a steeper or higher gear ratio with more HP.
qtband
St. Louis, MO
I agree with the above posters and will add that finding a clutch for the 19hp could also be pricey.
pblr89
hmmm there are so many variables in answers i have gotten with the 5 or even 6.5 hp engines. im basically trying to build a kart thats fast on the pavement but can go in some mud/gravel areas on trails and such. on pavement im looking for around 30mph atleast. suggestions? thanks
Bluethunder3320
if i was you,
i would sell the 19hp engine on craigslist and use that money to buy performance parts for the 5.5 honda.
is your kart 1 wheel drive or solid axle 2 wheel drive? do you have a clutch or torque converter?
pblr89
with or without the performance parts will the 5.5 be fast enough? and im not sure i have a couple im interested and looking at throughout the week from there im going to make my decision, is one better than the other?
ghostdog
Do you have a picture of what style kart you were looking at making?
If it is one of the typical one seaters like this 5hp+ will do the job.
If you are going to with a heavier beast like I have, similar to below, you want to definitely go with at least 6.5 hp.
pblr89
the one im really hoping to get looks like the top picture( 2 seat ) withought the above head brackets.
Jcotz
...wasn't there
NY
If you put in a 6.5 honda, and upgraded it with performance parts, you could probably get 15+ hp out of it. But that would take a lot of time, money, and knowledge. It would be well worth it however.
pblr89
what type of speeds will the normal stock 5.5hp give me?
what about stock 6.5?
upgraded 5.5?
how much extra work and money does it generally cost to upgrade all of those?
pblr89
i have another question, it looks like the cart im looking at is one wheel drive. is it cheap to convert it to both rear wheel drive? is there negatives and positives of this?
theo
If you plan to up grade a 6.5 to 10 or more hp., then buy a 13-16hp clone and a 40 series clutch. This will be a much better setup and cheaper.
