engine Q
tonks79
herts uk
Hi every1 at the moment i have a zip kart with a gx160 engine and my mate has a 7.5hp engine laying around dont know what make it is but has vanguard sticker on side of tank. Well what i want to know is if i could replace my gx160 engine with this 7.5hp engine without changing anything like engine mounts and that. Thanks alot.
If it's a real Vanguard, it's a Briggs. Maybe some chinese manufacturer has used the name. Post a pic.
Chances are, the mounting bolt pattern will be the same. Odds are also good that you will have to alter your chain and throttle linkage.
tonks79
herts uk
here it is its just i can have it for nothing but need to be quick as he tryin to sell it as h needs rid and dont wanna drive all the way to his if i have to change alot of things.
i can have it for nothing but... he tryin to sell it
So... Free, or not free?
Anyhow- genuine Briggs Vanguard series. If you post the model/type/code info located on that data plate, we can probably find more info. Aside from the recoil, I can't see what else it may need.
If it's free, take it! Even if you decide not to use it, you can give 'er a tuneup and sell it for a few bucks.
The little circled symbol tells me it's a B&S.
As toystory said you'll need to change at least the throttle & chain but, go for it
