Engine problems...
gokartt
India
My engine just will not idle. Its an Industrial plus 133432 briggs and stratton. When I start it (on fast) it runs pretty smooth but when i lower the speed controller to slow, it just dies. Runs ANY speed but slow. Some help?
gokartt
India
Honestly, I don't know much about these engines. This one here is pretty new so I don't know why it should have such a problem. How do you check the plug and the spark anyway?
Pull the wire that's on the spark plug off, take a spark plug socket or some other deepwell socket, put that on the spark plug and take it out like you would any other nut or bolt.
Sent from my SAMSUNG-SM-G935A using Tapatalk
gokartt
India
Could a water clogged air filter cause the problem? coz while moving the kart, a water hose nearby had a loose pipe and sprayed water right on the engine. ik it sounds silly
It would make it harder to start, but it shouldn't keep it from running. It would also make it run like crap for a little bit until the water got out of the engine. When I've cleaned my ride on sprayer for fertilizer with a pressure washer, some water gets in through the exhaust and it makes it sputter and backfire like no other.
