Engine Problems
Duckie92
Arizona
Hello. So my Dn150 Baja putts alot and revs when i still have my foot on the gas pedal. When i try to climb hills though it putts badly and kinda smells like alot of gas and something burning. Not sure if it's the silent muffler i put or it'/ms not getting enough gas or something. I have a video of what it sounds like but it's not the greatest and no picture. Just want my buggy running again before my brother comes home on the 23rd.
Bwdeaton
Dayton, Ohio
Sounds like it could be running rich. If you changed the muffler with something more restrictive, the engine ma be getting less air and need the carburetor jetting adjusted.
Duckie92
Arizona
Okay. It was running fine the way it was till the muffler ring moved and the plastic cover for the camshaft i think its called that. Air to fuel mixture screw ,which way should i turn it and how much?
Bwdeaton
Dayton, Ohio
Yeah lean is definitely likely if the muffler connection is leaking. I was thinking it might be rich because you said it smelled like gas and the muffler had been changed.
---------- Post added at 05:15 PM ---------- Previous post was at 05:11 PM ----------
Normally these carbs for gy6 engines are jetted too lean from the factory because they are supposed to meet emissions. I usually change the main jet up a size or 2 to get it running better and maybe a little more if I change the airfilter to be less restrictive.
