Engine problems
Jcotz
...wasn't there
NY
Hi, right now I am having a problem with my tecumseh 3.5hp engine on my mini-bike. It starts up well, and when I give it gas it works, but when I decelerate and fall back to idle it stalls out. I suspect it is running lean, but I just cleaned out the carb and replaced the float, so I don't know. I have not had time to get a plug reading, but what would be causing this?
Nodroz
Belgium (Europe)
I think it would be best to open your plug and see how it looks like. You say it's running too lean, so I suspect it's more white. You could also try to set your idle screw a bit more in.
exenos
Project Nut
If it stalls when you decelerate then it might be the clutch not fully disengaging. Try slowly decelerating from flat out and see if it still stalls out. If it doesn't stall out, clean the clutch or get a new clutch.
Bluethunder3320
i had a burnt out clutch once and it didnt stall out, it just had a struggling idle and it went on its own
fixed it by shortening the spring in the clutch haha.
