Engine problems - Accelerates out of control
Ladon
I bought a used Yerf Dog 2 seater off road go kart recently and al though it runs its very unreliable. The previous owner put on a pretty powerful 2 cycle Arctic Cat snowmobile engine. At first it had trouble starting so i cleaned the carb and it began working ok but had to keep the throttle pressed to keep it running.
I have it up on jack stands now so i could press the throttle while it was running and it not take off but now it starts accelerating like i have the throttle wide open when i dont even have it pressed. When it does this i have to throw the kill switch to stop it. On the next pull of the cord it starts up again at full throttle then dies in a few seconds.
I bought this for me and my kids to use and to have my 14yr old get more familiar with driving but right now im even scared to get in it.
Is this something thats easy to fix and get the engine running right or should i look into taking it to a shop to get tuned? How much should i expect to get it tuned?
If all else fails i was think about putting a 212cc Predator on it so its not such a beast and its more reliable.
Any thoughts on this?
Ladon
Thanks for the reply, It is not closed, When i had issues with it starting i tightened a screw on the carb so the throttle is more open so it would stay running without having to have one of my kids in it holding down the gas. If i dont have this screw down it wont start. I did notice when i cleaned the carb there is another screw maybe for a/f?
Im not sure if the green circle screw is for anything, the blue one is for the a/f i think.
The red screw here is the one i adjusted, and here is a side view of the a/f one.
Here is how far open the throttle plate is:
Yes, it's revving high because the throttle is open too far; back the idle screw (red circle) right off, then turn it back in until it just touches the linkage plus a full turn; that should be a good starting point & adjust while the engine is running...
As for the "a/f" screw, I'm unfamiliar with this particular carb so, I can't be sure if it is or not; if it is, screw it all the way in then back out 1.5 turns; again, it's a good starting point...
Ladon
I think we are making progress!, I followed the instructions on the throttle screw and was finally able to get it started, i had a hard time keeping it running but at least it didnt take off like a bat out of ****. Now time to get it adjusted so it stays running.
Here are pics of the two screws, Blue and Green in the pics above. Anyone know what they are for?
Blue
Green
Also to note i think its getting flooded, The carb is dripping gas.
ML-TOYS
long island, new york
The one without a point just put fully in. The other one try just snugging it gently then backing off 1 1/2 turns and adjust as needed.
Also i think you may want to add a return spring on the carb.
Ladon
Thanks for the help, It does have a spring by the way, The 2nd pic in post #3. Under that orange rubber piece there is a torsion spring.
