engine problem
ed1380
Banned
ATL, GA
So I got an engine for free.
I cleaned it up and it still wouldn't start. (yep I broke a ring and stripped a bolt)
my dad took it apart and cleaned everything, and it still didn't work
it has a spark that'll jump 3/8 of an inch, great compression(we put in a thinned head gasket), and we use starting fluid so the carb aint that inportant.
it doesn't start no matter what we do
we think someone messed up the timings(cams)
is teh spark really supposed to hit twice per cycle
once at TDC when compressing and once when done expelling exhaust
this for reference and this for pics
@robert- why did you close the other thread?
do you really hate me that much
kibble
I banned myself
On these small engines the spark fires every time the magnet on the flywheel goes past the magneto. So yes it would be twice. You should be able to fix the timings, if that's what the problem is, by looking at the gears or chain or whatever yours has and they should have some sort of marking as to where their initial position should be.
BTW, robert hates me too. He closed my other thread as well. :(
(Just kidding)
ed1380
Banned
ATL, GA
(Just kidding)
yeah I saw that , but at least he gav you a reason.
so it should go off twice?
kibble
I banned myself
If there's nothing between the spark plug and the magneto to control when the spark goes off, then yes, It'll go off every time the flywheel turns once. That's how my engine is.
RobertD
Administrator
Texas
hee hee, no offense. When threads start wandering it's not a bad idea to start another one. I miss a lot of stuff on other forums b/c I just see the title, but the actual discussion has gone to another direction (that I might be interested in!)
about the engine -- so it's got spark but you can't get it to fire, at all? Could be someone didn't re-assemble correctly. Take the side of the engine off, position the piston at top dead center, and look at the tiny little dots (one on crank, one on cam). They should align.
2or3wheels
Minneapolis Minnesota
If the timing is correct the carb may be not adjusted and what not, Otherwise before you do all that check the compression you need 80 PSI for a weak motor for it to run.
RobertD
Administrator
Texas
also, if the gaskets are bad / the carb isn't tight, you're going to have a vacuum leak and it won't run properly. Should run with starter fluid, just won't keep running...
ed1380
Banned
ATL, GA
we redid the timings. turns out it was 3 teeth off.
now it'll start on starting fluid and sputter for a second.
now I need a starting assembly, and the diaphram for the carb.
RobertD
Administrator
Texas
and a gasket... especially if you pick up the engine by the tank/carb, you're going to loosen that connection and have problems running.
Why do you think it's the diaphram?
ed1380
Banned
ATL, GA
I took apart the carb to clean it, and the diaphram is still. (unmovable stiff)
the little valve flaps had a bunch of crap on them, but I cleaned that out.
I'm going to a small engine repair shop today, so we'll see if I can get some stuff
ed1380
Banned
ATL, GA
I got the diaphram. it'll work for a few seconds if you periodicly spray starting fluid.
we put gas in the tank, and when it got primed and it started flowing, then engine started to backfire.
(backfire is when it makes the engine rotate backward?)
What comperssion should it give?
what could be wrong? we matched teh dimples.
mikeandike
mabe theres too much compression so the fuel preignites itself before the spark plug fires and the piston isnt at the top?
ed1380
Banned
ATL, GA
we thought they broke cause we were using the flywheel to start it, so we got a starting clutch for it, and after the first pull it broke.
could it be the super compression we have going?
ed1380
Banned
ATL, GA
IT"S ALIVE
Well not any more. the carb is clogged up.
the problem was that teh flywheel nut wasn't on tight enough.
now it has a steel key, is on extra strength thread locker, and is tightened with a foot long adjustable wrench to the point of no return. (quite litteraly)
drives pretty good too.
not bad for a 3hp tiller engine
how tight is teh chain supposed to be
RobertD
Administrator
Texas
the chain should have no more than 1" of up and down movement IMO.
ed1380
Banned
ATL, GA
me and my dad spent a whole day trying to mount the engne so the chain was tight.
in teh end we got rid of a link
