engine problem, need some help
vandancouver
just got my first go kart (at the ripe age of 26)
it was a old clunker until i completly took it apart, rebuilt the engine (5hp briggs from 1984), and re did everything
over 4th of july weekend we were all having a good ol time with it when all of a sudden it kinda did a bang and a few sparks came out...then it died. now when i pull on the rope it just spins and spins..there is still spark. i think* i broke the rod/piston but im not to sure. i pulled out the spark plug and looked in there as a i pulled, and didnt see any movement. thats where i would look isnt it?
when i say it spins freely..the whole shaft type thing does, but not the gears..nothing catches at all, hard to explain. ive never blown a rod so im not sure.
any ideas?
the model # of engine is 130232-1638-04-84111309
you can see it on the briggs website..
if i just need to buy a new engine i will. just curious if its a possible/economical way to fix this
thanks alot,
dan
p.s. sorry i didnt see this seciton of the forum or i wouldve posted here first
pmat
noob
lake wynonah, pa
Check your flywheel key, it would be the cause of what you described, and it could easily have sheared if you didnt torque it back on to spec when u redid the motor.
vandancouver
it isnt the flywheel key i know that for sure. if it was just the flywheel key it would still spin the whole motor just the timing would be off, etc
pmat
noob
lake wynonah, pa
I believe its a sheared key, but it could be the crankshaft. very unlikely but possible. yesterday i broke a rod in my mower, and everything would spin but the piston wouldent move.
vandancouver
the piston isnt moving. i pulled the plug out and looked inside for movement as i pulled..and nothing was happening. it was still getting spark though. i didnt hit anything or stop hard, etc to make the key shear. but i guess ill check that too.
my wifes brother thinks (he says he knows) its the rod
pmat
noob
lake wynonah, pa
If it is the rod; the clutch or whhatever you have at the end of the shaft, should still move. its not easy to break a crankshaft.
vandancouver
it does still move at the end, but it dosent move the actual gear that spins the wheel etc.
hard to explain but when i pull i see the crankshaft spinning, the thing that the pullstart spins is still spinning, and its spinning on the other end of the crnakshaft...but not grabbing a gear. i guess ill check the flywheel key..but when i pull the plug nothing is moving uderneath
pmat
noob
lake wynonah, pa
now that u say it that way, it does sound like a rod, its worth checking the key before u replace the rod or whole engine.
