Engine Only Runs When Fully Choked
Misun
Braham, MN
Well, tonight, I got around to the third kart I have. Purchased it from some guy and the second I got it home it wouldn't run. Ran fine when he was driving it around his yard though, lol.
Anyways, problem after problem with this kart and not having the time, knowledge, or money to get it fixed in any way, it sat outside for about a year. Just recently I thought I should try to do something with it, seeing as it cost $1000, I wasn't just going to let it be a lawn ornament. When I tried to start it, it wouldn't. So after looking up the basics on small engines I tried my hand at fixing it. Tried cleaning the carb and it still wouldn't start. Being frustrated with that, I decided to fix the original thing that made it inoperable, the torque converter. Long story short, after fixing the things I screwed up when trying to fix it originally (if any of that made sense) I got it to run.
This consisted of me having to pull off the combustion chamber and re-time the piston with the valves. While this was done, I cleaned what ever I could. After putting it all back together, it ran. Though it has to be completely choked just to idle. When given gas, it rev's (though not much) and sounds like it's going to die. When taken off choke, even the slightest, it dies immediately. It can be started right away with one pull but only when fully choked. I've read that this could be due to not having the carb cleaned enough, though those problems the engine would idle at half choke.
So is the problem that I don't have my carb cleaned enough? Or does the problem lie elsewhere?
It's a Mitsubishi 6hp GT600
And why is it that every time I try to spell carb, I spell crab? Dam thee derp fingers. DAM THEE.
Odds are very good you didn't get the carb clean the first time through. There are some very small, easy to miss passages in there.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Boil the carb in lemon juice for 20 mins and rinse it well. After this, spray it real well with WD40. This is condensed. Go on Google and search "Clean a Carb with Lemon Juice" or similar.
LKVL
MN
I have the same engine doing the same thing. I'm almost sure it's not the carb. I've had it off and cleaned a number of times and made absolutely no difference. Not sure where the problem is and can't seem to find much info on that engine. If you figure it out I'd like to know what it is. I haven't put a compression tester on it yet.
Misun
Braham, MN
Well, after finding the EXACT kart online and reading reviews (I'm assuming with the same engine) it isn't that great of an engine. I've heard people complain of it not carrying children up slight inclines, complaints of the belt being worn in seconds, people saying that it keeps breaking down in different ways... yeah... IDK if the engine is really worth trying to fix. The kart itself is well built, everything I would want in a kart.
I'll keep trying. I don't have the money for a new engine, so might as well.
LKVL, where you from? I'm in MN as well, lol.
r_chez_08
Should be in the shop...
Cornwall, UK
Looks kinda like a Honda clone. Sounds like a carb problem, lean condition. Usually caused by an air leak or a fuel restriction, often in the main jet of the carb, probably located in the carb bowl.
It may be poor factory gearing that makes the motor gutless.
r_chez_08
Cornwall, UK
Glad it works ok now. Good luck with the belt, loads of the reviews say they burn out for some reason???
I think the kart may be geared for too high a speed, and limited to 25.
Therefore it doesn't have enough torque to climb hills and therefore burns up belts.
