Misun
Well, tonight, I got around to the third kart I have. Purchased it from some guy and the second I got it home it wouldn't run. Ran fine when he was driving it around his yard though, lol.
Anyways, problem after problem with this kart and not having the time, knowledge, or money to get it fixed in any way, it sat outside for about a year. Just recently I thought I should try to do something with it, seeing as it cost $1000, I wasn't just going to let it be a lawn ornament. When I tried to start it, it wouldn't. So after looking up the basics on small engines I tried my hand at fixing it. Tried cleaning the carb and it still wouldn't start. Being frustrated with that, I decided to fix the original thing that made it inoperable, the torque converter. Long story short, after fixing the things I screwed up when trying to fix it originally (if any of that made sense) I got it to run.
This consisted of me having to pull off the combustion chamber and re-time the piston with the valves. While this was done, I cleaned what ever I could. After putting it all back together, it ran. Though it has to be completely choked just to idle. When given gas, it rev's (though not much) and sounds like it's going to die. When taken off choke, even the slightest, it dies immediately. It can be started right away with one pull but only when fully choked. I've read that this could be due to not having the carb cleaned enough, though those problems the engine would idle at half choke.
So is the problem that I don't have my carb cleaned enough? Or does the problem lie elsewhere?
It's a Mitsubishi 6hp GT600
And why is it that every time I try to spell carb, I spell crab? Dam thee derp fingers. DAM THEE.
