Engine mount
jjroga
Hollywood FL
Would this kind of engine Mount be possible to mount on here. Like can the mount just clamp the piece in the middle of I were to drill holes.
Atlanta, GA
You'd have to remove this, and even then it's hard to say.
anderkart
Surprise Arizona USA
jjroga,
The United Kingdom BIZ kart website seems to be listing the correct angled motor mount for your kart:
Here's the link: https://shop.bizkarts.com/Catalogue...unts/Engine-Mount-Sloping-Each-60040-046-0011
The BIZ kart shop in the USA (in Florida) doesn't show any motor mounts on their website, but they probably have them in stock. Have you already tried calling them and ask? (make sure you tell them what engine your going to instal)
Here's a link to their contact info: http://www.us.bizkarts.com/contact/
jjroga
Hollywood FL
I have already come in contact with them. They have no parts in the USA yet, but they are in the process of starting their office here.
anderkart
That BIZ motor mount ordered from the United kingdom website would cost you around $76 including shipping. That's not much more after you'd include shipping charges from BMI...
You might be able to use an aftermarket 15-degree motor mount similar to the BMI picture you posted, but you'd need to find one that uses a single bolt for each of the lower frame clamps; instead of the dual-bolt design that BMI mount uses. Then you wouldn't need to remove that slotted metal bracket thats welded in between your 2 frame rails, that metal bracket would function instead of using the lower frame-clamps, just exactly like the BIZ motor mount does...
But first, you'd need to make absolutely sure the distance between your 2 frame rails (and the diameter of each rail) on your kart is compatible with an aftermarket motor mount.
I can help you figure that out; if you measure & post your karts frame rail diameter, and also measure the distance between your 2 frame rails where the motor mount goes. Measure your frame rail spacing from the 'center to center' points of those 2 rails, like the Info and pic you'll find at this link: http://www.out2win.com/catalog/enginemount.html
