Engine mount troubles
mikeb89gt
Mid-Michigan
Ok I got my 11hp electric start H.F. engine today. I was anxiously awaiting its arrival so I could get it mounted and than wait for the converter which should be here Friday. Well I put the motor on the mount started to get the bolts in and realized that if I use that mount the jackshaft and the engine shaft don't line up. Its off by a couple of inches at least. Now I have to get some kind of a plate made to attach the motor.:furious2:
mikeb89gt
Mid-Michigan
Was just looking at the jack shafts and I currently have a 14" and the next size up is a 19". Do you just put washers behind the driven unit on the jack shaft to push it out? How hard are they to change?
mikeb89gt
Mid-Michigan
How do you take the jack shaft off? I'm going to take it off tomorrow and measure it, I'm thinking now that I may only have a 12" and I'm hoping that a 14" will do the job.
