Here's my take;
GROUP 1: First / Cheap / Easy (without opening the engine up). Here the goal is to reduce restrictions and improve flow in/out of the engine overall.
High flow exhaust: (good idea, but will be noisier)
High flow air filter: (excellent idea, stock air filters stink in so many ways. Don't spend the money, make your own out of a soup can)
Adjust spark plug gap: (try it and see, generally stock works well)
Check gasket alignment: (just to make sure)
Oil: (why would you use crappy oil and leave it in there forever?)
Re-jet carburetor: (IF needed, check the sparkplug color)
GROUP 2: After Group 1, you're going to start opening the engine up. Here you're after actual gains in flow in/out of the combustion chamber and higher pressure during combustion.
Advance Timing: (Good idea, but watch out for detonation (pinging) and harder starting.)
Increase compression: (Good idea, but watch out for detonation (pinging) and harder starting.)
Porting: (GREAT idea once you have the head off)
GROUP 3: After Group 2, you're going to start spending money and tearing the engine completely apart. Here you're after more rpm, understanding that rpm = hp (and not torque).
Remove the govenor: (take it clear out, don't just bypass it)
Aluminum flywheel: (AND a good Connecting Rod!!!)
Upgrading valve springs: (if you don't want to use valve float to limit rpm)
Group 4: After Group 3, if you're a racer and/or want that last %. IMHO, these items will take a dyno to tell the difference.
Reduce drag: (watch head temperatures, do NOT cut metal fins off!)
Index the spark plug: (cheap/easy enough to do anytime, but it'll likely take a dyno to tell the difference)
15-degree mounting plate (for less oil in the crankcase?)
Super-Duper Synthetic Oil
