Engine missing
Shawn drifts
Timing is 100% correct..... Retarded 1 tooth and advanced 1 tooth.... This is obly where is starts
Has trouble starting
Valve clearance is flawless
Have touched carb from when it was running good
Backfiring through carb
Im thinking coil or cdi
My cdi box has a huge nipple on 1 side of it from i guess getting too hot
Warning: turn volume down
http://s418.photobucket.com/albums/pp270/no_refuse/?action=view&current=3019d47c.mp4
Grimace
Mr. Furious
Do you have an exhaust pipe or muffler or is the exhaust port just the open hole in the head? No exhaust can lead to a crystallized valve or at least a warped one which may cause the problem you are having.
Shawn drifts
Tried 2 different heads..... Both open head, no exhaust, same results..... Ill slap exhaust on right now and double check
Bluethunder3320
when you run an exhaust straight out of the block, the engine runs way too lean for stock carb jets
stalling out when you accelerate means its running lean
Bluethunder3320
well i cant guarantee it, flipping the intake manifold back is a good idea (if you have clearance issues with that bar then i guess you cant.)
on some engines i notice the intake port/flange isnt symmetrical so if you flip it the gasket wont seal. not sure if this is the same case with yours.
also an air filter will help (similar to why you need an exhaust), the carb is tuned to run with a filter. you can buy a K&N foam pod filter for $20
Shawn drifts
Bluethunder3320
idk about that... most of the time you cant take 2 different brand engines and combine internal parts unless theyre exact clone parts.
timing wouldnt change because the piston still tops out at the same time.
now a problem i can see is, if the strokes are different (because you keep the rod from the one motor) you can have low compression
do a compression check and if thats good i dont see a problem using the mixed parts
Shawn drifts
Well tdc is still the same.....
Hmmmm time to take off valve cover to double check when valves are opening.... Hmmm
I dont have an adapter for my compression tester :/
Bluethunder3320
check the valve clearances thats a good idea... to narrow down the problem. however i dont know what engine you should check the clearances for? hahaha
put an exhaust on it, and air filter, that could be the problem
just read the part about the CDI... hmm
sorry im not much of a help anymore haha
