Mrenglish90
Hey I'm having an issue with my cart. It's a carter brothers xtv2150 with a gy6 150cc clone. When I first started working on it, it had no electrical. Got that squared away then found out the relay and starter were bad. Replaced both of those. With the electric system working and a new starter engaging, things started looking up. Tried to fire it up but the starter just spun the gears. Checked for spark and was getting a great blue arc. Tried spraying start fluid into the carb. Tried spraying a little straight into the plug hole. Nothing was working and now, the flywheel seems to get stuck at a certain point after trying to start so much. I can back it up with a socket wrench but when I go to turn the key, the flywheel gets stuck in the same spot again.. What do I do now?
