Engine identification help
EBACH
va
only number i could find on my motor is 13 with a small 1 by it. i am wondering how i figure out what 5hp briggs model i have? because i bought a spark plug today that said fits all OHV 5hp briggs motors and it is a taaad too long. bottoms out. the motor is not new, it has been rebuilt and repainted. so the numbers may be cover up. it has been rebuilt with racing head and carb. would this make a difference? any help is appreciated, thanks.
EBACH
va
:oops::mad2:
very new to this. only been reading a little here and a little there when i can.
now another question: #35 chain or #40 chain for a 72 tooth sprocket? seem to only see #35 for 72t.
im trying to run 10t front, 72t rear.
Do you already have a clutch, chain, or sprocket? If so, measure the pitch (distance from pin-to-pin on the chain, or point-to-point on the sprocket. If not, use whichever works out better for you.
EBACH
va
i do have a clutch that came with the motor, but im going to replace it with a new one. ok thanks. looks like im going #35 chain.
ID numbers for B&S engines are usually on the starter/blower housing; here is a guide to help you find & decipher the numbers.
However, if the housing has been changed for any reason, the numbers will not match the engine & there's no way of knowing whether this is the case.
Re: Clutch, sprocket, chain: You'll need to double check but, I'm not sure whether a #35 clutch is available in 10t, I think the smallest is 12t, in which case, you'll need an 84t axle sprocket to achieve the same ratio
EBACH
va
what adapter hub would i need to make this work for a 1in rear axle shaft??
smgs92
I'd go with a #420 chain it is pretty much the same size as a #41 but is a lot stronger since it is a motorcycle chain(the smallest available) and you could run your 72t instead of the 84t
EBACH
va
thanks!
good idea, but its only going on a 5hp Briggs racing motor. im thinkin #35 chain will do. now if its breaks..#41, #420 chain here i come.
EBACH
va
it seems i can not find a 10 tooth #35 chain clutch for the 72t #35 chain rear sprocket. and can not find a #40 chain 72t sprocket to go with the #40 chain clutch. is there not a match where i can get 7:1? or did i overlook some sort of adapter plate?? i have a 1in rear axle.
EBACH
va
$150 for a clutch...good lord!!
and those two sprockets look like they are the clamp style, but i dont see the bolt. are they clamp or do you weld them on??
thank you for your time
anderkart
Surprise Arizona USA
Thats a high quality race clutch, I havent been able to find any of the cheapo clutches avalible in #35/10-tooth.
Yep those sprocket hubs clamp on and use a 1/4" key.
EBACH
va
i think im going to have to go with the 12 tooth cheapo one, with an 84 tooth sprocket. i cant spend that much on a clutch right now.
zbuck
Ft. Wayne, IN
:wai: Spark plug should be Champion RJ19LM or equivalent. I hope you did not try and start it with that OHV plug. If so may have damage to the valves/piston. Engine numbers should be on top of the shroud or on the carb. side of the shroud.. Looks to me like a Kool-Bore engine (Tater digger).
EBACH
va
bought the correct plug, and it is a Briggs and Straton plug number 796560. and no, i didnt try to start it with the OHV plug.
yeah i found some numbers on the shroud last night. they are;
model#130202
type#3131 01
code#91010407
zbuck
Ft. Wayne, IN
:wai: 13 C.I., Basic design engine, Kool-Bore, year 91. It looks to me that the governor has been removed, if so I would pull the side cover. If has a stock rod with the sheet metal dipper, you are asking for trouble if reved over 3600 r's. Yes that engine does have the Raptor carb. As for the head, the Raptor head has three mounting legs on the shroud side agaisnt one for a stock head. Glad to hear you bought the correct spark plug and did not try to start it with OHV plug.
EBACH
va
:oops:newb questions: its a kool-bore motor not a briggs and straton? or is kool-bore some technical racing modification term? what are mounting legs? are they behind the shroud?
zbuck
Ft. Wayne, IN
:wai: Kool-Bore is a B&S engine. Kool-Bore meaning Aluminum cylinder instead of a Cast iron/steel cylinder. The mounting legs are cast into the head to mount the shroud. The only flattie 5HP hortizontal, B&S produce for racing is the Raptor engine. although many have built racing engines out of the 5HP hortizontal I/C block.
EBACH
va
might be helpful.
