Engine ID numbers
Stuartburton56
Scotland
Looking to identify what engine I have so I can buy recoil starter. Any ideas 💡
Look for a plate or some laser etched numbers on the block. May have to strip shrouds from engine. May even be on a sticker? Probably a 5-6hp engine though.
Stuartburton56
Scotland
Couldn't see anything even when engine is out ,but as you I might need to take of a cover plate first. I wasn't want to buy a new recoil starter in case it's the wrong on .never had one on it when I bought it
Stuartburton56
Scotland
Does it have compression when you try to turn it by hand? You may be starting down an expensive rabbit hole with the engine.
Yes I gave it to a guy that fixes of road bikes and quads to check it ,he saying has a spark and compression
I think it is in the link. Talk to Karl on here, he works on and has access to that stuff. His user name is Karl.
FlyFrog
Kankakee Illinois
its a techumseh 5 hp, I have one and love it, if your model has the oil sensor remove it, if you take a turn the oil will slosh away and cause the engine to turn off
