Engine ID Help
Got this unknown engine with a package deal last weekend. All I know is the seller said it was off a snowblower. Missing air filter assembly and pull start. Only markings are on the top of the flywheel shroud. Thanks! Adam...
Gokartbill
Atwater,Ca
Definitely a Tecumseh. Can tell by the round shroud on the front of the motor. Looks like a 8hp model, maybe a hm80. The snowblower was probably a mid 70's model MTD or Ariens.
Anywhere else I can look for numbers or something more concrete so I can start finding parts for it?
Russ2251
AZUSA:Powered by LAWN-BOY
Anywhere else I can look for numbers...
Nope.
A long shot....
Try applying ketchup to rusted area that is obscuring numbers.
The ketchup contains acetic acid (vinegar) and is sometimes successful in removing rust to the point where numbers may become legible.
I have repaired shotgun barrel finishes using this method and discovered hidden numbers.
Tried the ketchup idea, let it sit on the numbers for a few days, no go. :( thanks for the idea though!
Anything else I can look for? I plan on tearing the motor down and going through everything anyways.
Okay I played around a bit in Photoshop to reveal some more digits...
If I'm not mistaking, the number starts with
I45 but since that's not possible it'll be 143 ;)
143- then I cannot identify that digit 7 (or maybe 5?) 86122 you know the rest :D
which leads me to this engine model:
143-786122 craftsman
http://www.partstree.com/parts/?lc=tecumseh&mn=143-786122+Craftsman&dn=EHM1004159135G-EN
And that'd be a HM100-159135G model wise. maybe HM100-159409P I'm not too sure about that.
http://www.jackssmallengines.com/Jacks-Parts-Lookup/Model-Diagram/TECUMSEH/108791/16943
your's is from May 16th, 1978 btw (single digit year, three digit day of the year, line and shift code)
zbuck
Ft. Wayne, IN
:wai: It is definitely a Tecky. Try this, pull the fan shroud and then on the inside lay a piece of paper over the numbers and rub with a pencil. I have used this trick before when the numbers were not accessible from the front side.
Yes...the 143 prefix is the indicator.
If that number was 500.xxx.xxx it would be a Briggs & Stratton.
keep in mind that I only 'guessed' the 143 since I read I45 and assumed it's a Tecumseh...
:eek:
So yeah...
although I'm rather confident about what I posted above,
I still wouldn't place any bets :D
