Engine I.D.
zbuck
Ft. Wayne, IN
:wai: Buddy of mine brought me this engine: WG200-6.7HP, engine # WH17E08875715. Can anyone tell me who made this engine? As I need to change the sump cover and the crankshaft. It came off a generator. I realize it is probably a Chino engine. Any help will be appreciated. Thank you for your time. Don B.
It would, but then again...
maybe not.
I don't know to be honest, can be a gx160 clone with a bigger head, can be a gx200 with a smaller bore, can be almost anything in between.
And.. it can also be a typo ;)
Very true but, a GX160 just happens to be 163cc & the bore/stroke measurements are the same...
So, zbuck, it looks like it's a GX160 clone; Honda rate the original at 5.5hp, I have no idea where the chinese are finding an extra hp but, it should be ok to run a kart... mine is :)
zbuck
Ft. Wayne, IN
:wai:Thank you guys for the replies. I am trying to find a dealer/distributor for this engine here in the US of A. As this engine came off a generator I need a different sump cover, and a crankshaft. As the cover on this engine is to mount the generator and the crank is tapered. I went to the site provided by itsid, but no parts info. If I can find the parts, the engine is going on a fun kart in stock form. Don B.
yes, that's just the alibaba site I found the info on.
It'll be extremely hard to find parts from the exact manufacturer of this engine.
But, I would make a bet, that you can use just any clone for parts.
I suggest you take some pictures and measurments to verify.
:iagree:
What is the taper on the shaft (as in measurements at each end)?
What is the issue with the side cover?
Pics will help...
