Engine Help
assaultbob5
My shop teacher have me an engine which I believe is have a 5.5 hp B&S engine that came off of a tiller (I found this out after doing some research). When it ran, it seemed it would run at WOT and when I moved the throttle, there was no change in engine speed. The engine numbers are 126402-0206-E1. I want to turn this into a go kart but I can't really if the throttle doesn't work currently. Any help is appreciated!
Welcome to the forum...
Your engine falls into the class of "industrial engines", mostly found on power equipment, which are designed to run at a constant 3600rpm; they do have a throttle adjustment but, for some reason, it seems yours isn't working so, what you first need to do is post some pics of the throttle setup so we can see what is wrong...
assaultbob5
This is the one picture i have currently of the governor/throttle setup. If anyone needs more/different view of another part, let met know. Also, would removing the governor and just control the throttle on the carburetor be a way to fix it as a last resort?
Well, everything appears to be in the correct place but, I could be wrong...
That pic is with at WOT, correct? Can you shoot a pic with the throttle at the opposite extreme?
Absolutely, it's been done many times (actually, more often than not)...
However, removing the governor involves opening the crankcase as the working part is inside; what you see on the outside is only the control mechanism...
assaultbob5
This is what supposed to be closed and kill the engine with the kill switch. And I cleaned the bracket it all sits on since the last pic was taken about a week ago :wai:
The governor linkage to carburetor was taken off for this photo because I was running it without it earlier and manually controlling the throttle.
The carb linkage is, kind of, irrelevant at this stage as the governor holds the carb open when not running, I just wanted to see the difference in the throttle control mech...
This has me stumped, there seems to be no reason the governor would hold the carb open; the only other thought I have is the idle on the carb is set too high, not allowing the throttle butterfly to close...
Locate & adjust the idle screw out...
If the model number is correct, your carb should look like the one pictured below; the red circle indicates the idle screw...
assaultbob5
So I should try to lower the idle? If it makes any difference when I was manually controlling the throttle, if i closed it all the way it would slowly just stop running due to to low of revs.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
So when the engine was running, you had No throttle control at that linkage?
Because I had the same setup when my engine was stock, and without the engine running the throttle appeared to do nothing. But with it running it worked normally.
assaultbob5
Yea, i had no throttle control with the linkage
Did you turn this engine into a go kart? If so, what did you do?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I opened up the engine removed the Governor internals, then removed Most of that linkage crap for the governor. I bent a wire hangar for direct linkage from that throttle plate to the carb. I used the stock throttle arm for a while, but it was cheap metal and always wanted to bend. So I made my own from 1/8 steel.
Pic to follow
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Pics Keep in mind I have also relocated the fuel tank from stock location above this linkage. The silver below the ugly homemade throttle arm is what is left of the the stock plate that the fuel tank mount and throttle linkage originally bolted to.
