Engine help
jroberts
Barrie Ontario
So I finally decided to change my engines muffler since it's huge/bulky and I really don't like the look of it (pics 1 and 2). Will be making my own muffler out of round tubing that's like a millimetre or 2 bigger then the hole that's on the engine (pic 3). Just wondering if there's anything I should look out for when making my own. Also was wondering how to do the throttle hook up for my engine (pic 4). Normally I just put a spring in the throttle lever but I want to be a little more professional this time. I know I know I should do research first but I never really see any engines like mine... nor does the brigs web site have the engine any more so I'm a bit at a lose. And of course I want to put a kill switch on but I have no idea how... once again research but It does't have a low oil shut off that I could wire into. I'm assuming the part in pic 5 is a form of kill switch for when the lever goes all the way back so could I get rid of that and wire to it for the kill switch? Thanks for the help ahead of time
On the right of pic 4, you see an arm extend beyond the mech, that's where you need to attach the inner cable but, first you need to create an anchor for the outer cable, a length of 1/8" flat stock will do it...
Take the length of f/s & attach it across the top of the mech so it protrudes past the mech to the right; drill a hole for the inner to fit through, making sure to line up the hole with the attachment point in the arm; if you have thread taps, you can even tap a thread in the f/s to take a bicycle brake adjuster...
As for the kill switch, all you need to do is remove the wire from the existing switch (in pic 5), run the wire to a momentary or rocker switch, then from the other side of the switch to ground...
