HaM551
Hello
Can you guys ID all the major and minor points on the engine ?
with last pic whats the silver piece of metal down above the kick starter, just above the big circle thingy. Where is the clutch located ?. Gear shifter ?. what are the electrical cords for ?. What do i need to get ?. Second pic what is that black circular thing on the left above what i think is gear shifter but wont move, except pull out a little bit? and the circle pressed into the metal on right above gear shifter, it has 3 6 9 12 around it then a 60 in the middle ?
