engine help please ....... anyone????
davidbooth1991
Nottingham UK
Hi guys Dave here. At the moment I'm building my own go kart. And I was wondering what the best road was to go down. My kart will be full suspension full roll cage. I was wondering which would be the better not nessicerily easier way to go.
I could get a Genny engine gx 140 gx 160 etc and put a centrifugal clutch on it (easy way)
Get I beaten down moped 125ish maybe 180 cc that would be automatic on a variator and spring clutch ( kind of easy way)
Or just go to a full bike / quad engine 250 cc + I don't won't to go to mad with it as I don't really have experience dealing with big engines gear boxes I know how they work but had little experience with them.
Thanks guys Dave.
davidbooth1991
Nottingham UK
That sounds like a good idea, cheers. Your build is great by the way I've never seen a snowmobile in person and I defo didn't realise they can push 50bhp!! Do they get much bigger than that??? Thanks again
davidbooth1991
Nottingham UK
electric start
So I've been looking for engines ( generator, quad bike etc.) And was pondering with electric starts. My question is will any engine work with a starter motor if I can put a geared flywheel on???
Felineman
Death by misfortune
Muskoka Lakes,Ont
Snowmobile engines can get upwards of 1300cc and top out at over 200 MPH if you have the coin to buy one. The quad is easy cut the driveshaft to length and add a CV joint for your suspension. Thats how I was gonna do this one till someone posted that tank thread.
**** YOU Goliath tank.
davidbooth1991
Nottingham UK
Yh I thought of the CV joints on the axle but I'm just going to go with pillow block bearings and a live axle. And the last time I saw a snowmobile in the UK I was watching die hard lol
davidbooth1991
Nottingham UK
Can anybody help me out with this engine I got it in a swap there's no kick start I'll have to bump it. Its just the engine and carb. No exhaust, starter cdi, spark plug. Can I have any I'd on it please all I know is its a dealim 124cc driving a 4 speed box (no reverse) it came from a quad bike apparently cheers guys Dave.
88nightrider
Norway, Sandnessjoen
Getting parts and wire diagrams would have been much easier if you knew what make and model of ATV it all came out off.
There should usually be some more identification numbers stamped in somewhere. Usually on the crank case, around where the cylinder is mounted.
davidbooth1991
Nottingham UK
Hi guys just a quick question. I've got an engine (pictured above) the inside is nice and clean but I don't know if it will start or not the gearbox turns and so does the crank. If i wanted to bump start it would I just a ignition coil to my engine and the a spark plug????.
