Engine/Gearing Q's - Something a little different
cnodie1
Louisiana
Well today I scored pretty big on CL (at least that's how I feel :thumbsup:) and picked up a rolling chassis from a 4wd electric UTV prototype for a song. The batteries were bad so he started parting it out, stripped the front differential, lights, plastic, wiring harness and motor. That leaves me the chassis, wheels, steering, brakes, rear tranny, seat and roll cage. My plan is to put a 13hp predator on it with either a centrifugal clutch or a torque converter. Here it is:
Here is where my inexperience shines. You can see on the left side of the picture the spline drive where the electric motor was hooked up. That is 14-1 with the wheels if I am not mistaken (1 turn of the wheel turned the drive 14 times). That would be difficult to hook the motor up so I plan on leaving it alone. At the U-joint it is 3.75-1 (it used to run to the front diff.) My plan is to run the buggy from there.
Question time!
How in the heck should gear this thing???
-The cart is narrow, only 4 feet so I don't want a lot of speed. 25 mph max.
-It will need some power since the cart in total probably weighs 4-500 pounds and seats 2 (I am 6-5 230)
-For 25 mph I calculated the U-joint would have to be spinning at ~1600 rpm (20" wheels)
-To get 1600 rpm at the U-joint I would have to gear the motor down to.................... and that is where I lose it.
Help!
Any info or opinions would be greatly appreciated.
:welcome2:
the 1600 rpm at the U-joint seems plausible; and if that's a 3.75:1 ratio
the engine has to rum 3.75 times as fast to get there (6000 rpm exactly)
6k is very well doable, but with a 3.75:1 ratio that engine needs to have SERIOUS Torque (and mentally I already ruled out a cent clutch here ;)),
I doubt you'd be happy with any single cylinder industrial engine...
and that's where it gets really expensive already... a twin cylinder engine plus matching performance parts to get the 6k you need ...
it'd almost be cheaper to get a sled engine instead.
cnodie1
Louisiana
:welcome:
I am confused. If the motor spins at 3500 rpm wouldn't you have to gear it where it slows the motor down to acquire the 1600 rpm at the ujoint?
I probably wasn't clear sorry.
Oh.. maybe I got you wrong.
I thought the OUT-part of the u joint (the '1' of the 3.75:1 ratio) would have to spin at 1600 rpm.
But you meant the '3.75' had to spin 1600 rpm...
well then, that's much easier since in that case you can indeed just gear the engine down
industrial engines run at ~3600 max and you want it to run 1600 max so a 2.25 gear reduction will get you there (3600/1600)
and even better... with an overall ratio of 8.44:1 (3.75 * 2.25) you're geared down far enough to be in a reasonable range; still I'd say a TC will be necessary because of the weight, but at least that's something to work with already ;)
KartInfo by kartcalc.net:
Code:
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]RW diameter[/I]: [B] 50.8 cm | 20 in[/B]
[I]Total weight[/I]: [B] 500 kg | 1102.31 lbs[/B]
[/INDENT]
[B][U]ENGINE[/U][/B]
[INDENT][I]Original HP[/I]: [B] 13[/B]
[I]Asummed HP[/I]: [B] ~13[/B]
[I]Torque[/I]: [B] 25.71 Nm | 18.97 ft lbf[/B]
[I]RPM[/I]: [B] 3600[/B]
[/INDENT]
[B][U]TRANSMISSION[/U][/B] *
[INDENT][I]Final ratio[/I]: [B] 8.44:1[/B]
[I]TC type[/I]: [B]  series 40[/B]
[I]Lowest ratio[/I]: [B] 20.51:1[/B]
[I]Highest ratio[/I]: [B] 8.44:1[/B]
[/INDENT]
[B][U]PERFORMANCE[/U][/B]
[INDENT][I]Max Wheel Torque[/I]: [B] 527.31 Nm | 388.92 ft lbf[/B]
[I]Top Speed[/I]: [B] 40.84 km/h | 25.38 mph[/B]
[/INDENT]
[/FONT]
* transmission was calculated with TC 12->27 JS-in and JS out 16->60 Axle (which is 2.25:1 and 3.75:1 of course)
cnodie1
Louisiana
This is where my inexperience shines again. I don't know what the abbreviations you used mean, other than TC is torque converter :)
Also when I did a quick searched for the Series 40 TC all o could find were the individual pulleys or 2 pulleys but not connected like the smaller TCs are (they appear to be in a neat unit that is connected together, it's hard to explain sorry)
Thanks so much for working this all out for me. It's probably child's play for you but it's difficult for me :huh:
The JS stands for jackshaft. The driver and driven for 40 series TC's are bought seperately. You are thinking of the 30 series that comes with a backplate that makes it all look like one unit. The 40 series is not like that. You have several size belts for the 40 series depending on the spacing you choose between the driven and driver.
Sorry cnodie,
I added the numbers just to give you a starting point, if you want to play around with some number in a ratio calculator.
Then all the abbreviation would become more or less obvious;
but just as landuse said, JS means Jackshaft; in my particular example it's NOT the Jackshaft the series 40 driven mounts to, but a seperate one;
and it's completely virtual, just so I could feed the U-joints ratio into the calculator ;)
Regarding the Torque Converter:
the smaller series 30 TAV Kit (Torque A Verter) with the nice backplate will NOT work for you, the engine is too large, and the cart is too heavy;
it'll simply not hold up against that abuse for very long.
the larger series 40 is more expensive and slightly more difficult to install, true;
but it's the best option you have, and in the long term it's even saving you money, since you don't have to buy a new belt every week,
which you likely would with the too small series 30 (TAV Kit) ;)
cnodie1
Louisiana
So sid if I follow you correctly, I would need to hook the motor up to one JS with the TC 40 then have a 12 tooth sprocket from the JS to another JS With a 27 tooth sprocket. From the second JS I would have a 16 tooth sprocket drive a 60 tooth sprocket on the axle. Is that correct?
Yes, but not really, no;
let me explain :D
... in my particular example it's NOT the Jackshaft the series 40 driven mounts to, but a seperate one; ....
if it'd be just that sentence then it'd be exactly like you described yes... BUT further I said:
.... and it's completely virtual, just so I could feed the U-joints ratio into the calculator ;)
And that means, there is no real life 'second' Jackshaft involved,
it just was used in the calculator to feed the 3.75 ratio into the math, the ratio your U-joint is having ;)
So in real life your getting a TC driven unit and connect that to one end of the single jackshaft you'll need and let it drive a 12T sprocket;
then that is connected (via chain) to a 27T sprocket sitting on your U-joint,
and that completes what you'll have to add to the ratio.
(the U-joint then internally adds the 3.75:1 ratio I had to add virtually to come up with matching speed and torque values in the calculator)
Not that's fine.. the Comet was 1:1 in forward mode.. (IIRC 2.7:1 in reverse )
But you want to be slower in reverse anyways.. so that should be okay I guess ;)
PS the comet has a limited HP rating though.. I can't remember if it was 16 or 13 HP... so you might want to check that again, just to be sure your motor wont eat it's gears ;)
