I have a Baja Trax 196cc kart and it's being a bit troublesome. The kart will work fine for a while 30-60 minutes. Then it stalls out. Restart the engine and everytime you push in the throttle it tries to die, let off the throttle and it resumes idling just fine. Ive replaced the carb twice (screwed up the first one), cleaned it several times. Cleaned out the gas tank. Replaced the spark plug. Spark plug was blackened pretty good so I got a platinum plug. Any ideas what the problem could be? Everything I read says clean the carb, and I've done that, several times. Thanks in advance
