Engine Dies with throttle input
Glomtic
I have a Baja Trax 196cc kart and it's being a bit troublesome. The kart will work fine for a while 30-60 minutes. Then it stalls out. Restart the engine and everytime you push in the throttle it tries to die, let off the throttle and it resumes idling just fine. Ive replaced the carb twice (screwed up the first one), cleaned it several times. Cleaned out the gas tank. Replaced the spark plug. Spark plug was blackened pretty good so I got a platinum plug. Any ideas what the problem could be? Everything I read says clean the carb, and I've done that, several times. Thanks in advance
Also try looking for leaks on the engine side of the carb by spraying with WD-40 and a long nozzle.
When idling, spray and listen how RPMs change. If they change, there is a leak.
That was some Poboy advice to me, that may or may not help here. It's cheap and easy to test.
If it was a leaky seal, I assume multiple cleanings of the carb and re-installations might only make it worse?
ChromeRhino
Sounds like the choke gets giggled on to me. See if the choke is on when it happens. You may need a more solid linkage to hold the choke open due to all of the bumps and vibrations. I have saw it happen before so I figured I would suggest it.
DHC
Check the plastic insulator (between the carb and block... normally has a fuel line slot ontop of it to hold the fuel line steady). Those plastic insulators have a chance of cracking due to heat/cold/heat/cold/vibrations/etc.
If your driving it for around 30 mins or so, 'that' may be when the crack (if present) expands enough to allow air to slip past it, causing your engine to run poorly upon acceleration (too much air in the mix). There should also be a seal (as bob58o suggested) made ow/ a metal core... the rubber on the metal may have become torn/ripped (from all the cleanings, maybe?)... may need replacing.
Another thing to look for is a loose/wobbly fuel/air mixture bolt/screw (on the side of the carb, usually will have a spring wrapped round it to create tension on it... hopefully NOT broken off). IF, once set, you can wiggle it w/ your finger tip, it may be the culprit... but, basically, do as bob58o recommended (but id use carb cleaner vs WD40)
Joe-405
Enjoying New Projects
U.S.A.
I work for a small engine repair shop............take the platinum plug and throw it as far as you can away from the engine. Put a regular ngk plug in and try it. And if that doesn't work. The coil could be getting hot and shutting down IF the carb is ok. And if you have ethanol gas in it dump it out also. It only good for watering or killing grass !
