Engine Dampener
firemanjim
Just kartin' around....
Houston Texas
You really don't want to do that. It will cause problems for you with chain tension and what not..... Part of the fun is the vibrations from the engine as you ride around. The only reason generator engines use them is because the engine is mounted to the Genny and theyre both mounted with rubber pads, to help keep them from walking away.... :thumbsup:
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Actually... Engine dampeners are there to absorb harmonic vibration. Have you ever seen a piano tuning fork? When you tap it on something, the vibration produces a high-pitched sound, because each end of the fork is free to vibrate. If you held the other end, your hand would absorb the vibration and you wouldn't hear anything.
Keep this in your mind, but back to engines. Each time the piston(s) fire in an engine, a hammering effect is produced by the downward force between the rod journals and the connecting rods during the power stroke. On single-cylinder engines , thess vibrations are absorbed by the inertia of the flywheel, as well as whatever is bolted to the crankshaft. In this case it would be a centrifical clutch, however it could be a pressure washer pump, generator or anything else that puts a load on the engine. When you run an engine with no load, such as revving a car in neutral, the crankshaft is being subjected to tons of vibration, which is obviously bad for it.
So OP, you asked about dampeners for your go kart. Your engine already has a flywheel, and that's enough to smooth out the engine operation. Don't attach anything to the crankshaft, or you can cause an unbalanced load on the engine. If you look at the front pulley of a car engine, you will see a two-piece pulley separated by an elastomeric rubber which absorbs the engines pulses each cylinder firing. I could really get into this but I'm going to keep it simple stop here. Lol
Poboy kartman
Senior Moments Member
White Settlement Texas
Well.....there is a simple solution to this....although a bit of work and expense...
The problem is that putting bushings inbetween the engine and engine mounting plate is then the engine slips in the slots and maintaining chain tension becomes problematic......
Soooooo......here's the solution: Purchase or fabricate a second engine mounting plate identical to the original.....
Place it on top of the original....line up the slots and then drill 4 corner holes....
Now....you can either enlarge the slots in the original to accept a socket....or deal with tightening the engine mounting nuts with a wrench....
Put the bushings between the two plates...and use 4 bolts and locknuts in the four new holes...and the slots in the new plate to mount your engine.....now you can lock your engine in place and have some vibration dampening.....:cheers2:
I don't know about your car Brandon.. but mine has a flywheel for it's engine too ;)
and guess what the engine rest's on huge rubber as well :D
's called comfort (as if... :lolgoku:)
Anyway I think -as most of us actually- that OPs question was pointed towards cancelling out engine vibrations from the kart chasis (and thus the drivers behind)
not to actually try to remove whatever 'roughness' a running engine in itself will have.
And while this is possible it often causes more troubles than it's worth;
just as Jim said.
And the more you try to reduce possible issues with dampening the engine vibration hitting the chassis.. the more vibration leak through;
and at the end of the day you'll spend time and money for no noteworthy result ;)
So sticking with:
holds true for the majority :D
Ok guys I've been silent about this long enough. The cyclekart guys have figured out that if you sandwich a piece of 1/4" plywood between the engine and the mounting plate it will take out some of the harmonics (vibrations) going through the frame. I have not done this personally so I don't if it is true, some even make wood mounting plates for their engines. :stir:
:feedtroll:
