fattony
Ok as mentioned I have a Honda lawnmower engine. Similar to image below. I have tested it and all seems good. I also have a ride on mower gear box.
The question is , can I just fit a centrifugal clutch with a pulley to this engine ,to mate to the gearbox then use the gears in the box for forward neutral and reverse? changing gears only when revs below speed that engages the clutch.
thinking clutch like this
http://www.mfgsupply.com/gomini/gominiclutch/gominiclutchutility/gominiclutchcometscp350/202313a.html
your thoughts please.
