I had one like that. Take off the tank with the two nuts underneath it closest to the kill switch. Sand it down with some fine sand paper and perhaps clean it with carb cleaner to remove the excess paint. Get some rustoleum spray paint of your fav color and go ahead and spray it as it says on the can. You can also pull the air intake off with the two nuts that hold the assembly on and paint that as well with the same paint color if you like. If you wanna pull the shroud off (the red cover which the recoil starter bolts on to), theres about 5 bolts which hold it on. One is a bit tricky to find so take a good look around the throttle linkage for it. You can clean this off the same way as the tank as long as you dont put any deep scratches in the metal, or you'll screw it up. If you want to paint the coil starter a different color, there's 3 bolts that form a Y shape. You can paint this too since it's metal, but just be careful about getting too much on the rope. The muffler can be painted, but you'll need paint resistant heat. I painted my valve cover black (the OHV cover), so you can do something like that. The sky is the limit man, just let your imagination take over. Good luck. Later, I'll put a picture of mine up.
