Engine Bore Question???
tramont
Georgia
Im buying this engine next month and i wanted to what was the crankshaft size because i need to know so i can get my torque converter. Also if i remove the governor will i still be able to use the comet 30 series because i saw the maximum engagement is 3150
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
That engine's shaft is Tapered for use in a generator, just as it says. You're gonna want to find one with a keyway, because you can't mount a clutch on that shaft.
As for the governor, I'm not 100% sure, but they put the maximum for a reason. That seems a bit low, though since the governor allows about 500+ RPM.
Also, you didn't state a question regarding the bore. I now leave this open for someone who knows about torque converters. haha
r_chez_08
Should be in the shop...
Cornwall, UK
I think what it means by max. engagement is the rpm when the driver is fully closed/ in overdrive.
Yup, that engine is not for you. The reason being the crankshaft is tapered. If they sell one with a straight keyed shaft, then go for it. A comet 30 series is also only rated for 8HP, so you will be pushing the boundries a bit with that size engine. You will be eating belts at a rapid rate.
tramont
Georgia
ahh man thanks you guys do you know any place where i can get a good deal like that. I really dont know how much hp i need because myself i weigh 270 and the cart is a murray explorer frame i dont know how much it weighs. I wanted to go a pretty decent speed like 40+ i also have 18in tires in the back if that helps. Any suggestions?
Brandon1023
needs an oil change
I had one like that. Take off the tank with the two nuts underneath it closest to the kill switch. Sand it down with some fine sand paper and perhaps clean it with carb cleaner to remove the excess paint. Get some rustoleum spray paint of your fav color and go ahead and spray it as it says on the can. You can also pull the air intake off with the two nuts that hold the assembly on and paint that as well with the same paint color if you like. If you wanna pull the shroud off (the red cover which the recoil starter bolts on to), theres about 5 bolts which hold it on. One is a bit tricky to find so take a good look around the throttle linkage for it. You can clean this off the same way as the tank as long as you dont put any deep scratches in the metal, or you'll screw it up. If you want to paint the coil starter a different color, there's 3 bolts that form a Y shape. You can paint this too since it's metal, but just be careful about getting too much on the rope. The muffler can be painted, but you'll need paint resistant heat. I painted my valve cover black (the OHV cover), so you can do something like that. The sky is the limit man, just let your imagination take over. Good luck. Later, I'll put a picture of mine up.
Wow- did he baste it in roofing tar??? Ahh, I can't say much. Mine came from a cement mixer, and still had cement in a few places. Just clean it up, paint it, and you're good.
tramont
Georgia
Hey you guys!!!! Since I wont be able to get the tapered shaft engine, i looked around and found these to deals. http://atlanta.craigslist.org/nat/tls/3043016367.html and
http://atlanta.craigslist.org/sat/grd/3101845701.html. Which one should I go for? My mom dad intentions was to pay 180 for a engine. I think ill be able to talk down the man in the first link but the second one sounds to good to be true? Also do you think it has a keyed shaft? Also the pressure washer engine seems like it says 11 or 13hp I cant distinct it can you?
With the combined kart/driver weight, and the 18" tires, I would NOT suggest the 6.5.
First engine looks like 11hp. Second one, I'd be all over that!
