http://www.perr.com/phpBB3/viewtopic.php?f=14&t=9201
The engine uses a mechanical compression
release on its camshaft....so start-up compression readings will
usually be around 80-90 psi. If MCR is not working, readings can
be 120-140 psi.
I have oil coming into the air filter from the little tube that goes into the side of the case.
