Ellectrical shock from engine
MaineTimberFrame
Maine
I just got an old engine running again (my first small engine project). I disconnected the governor linkage and was controlling the throttle by hand and got a nice little shock. I am sure the reason is obvious to most of you, but not to me as I am just learning. Thanks for any advice.
JHen
Was it running at the time? If so, then you probably got shocked from the electrical charge the engine generates to operate the spark plug somehow.
MaineTimberFrame
Maine
yes it was running at the time. So is their a solution to this. Improper grounding or something. My fingers were on the throttle when I got juiced.
anderkart
Surprise Arizona USA
Some engines have a kill switch attached to the throttle linkage near the carb. Kill switch wires will shock you if you touch them while the engine is running. Is there a wire conected near your carb that you might have touched?
:iagree:
The other possibility is a small pinhole or cracking on the spark plug boot or wire, or carbon tracking, and you were just too close to it.
