Hi,
Whats the math/calculation behind figuring out how much power the motor will draw from the batteries based on the currest setup. what factors should be considered (eg. weight, RPMs, etc.)
As an example my current setup:
Motor: 36v, 500w, 3000 rpms max
Controller: 36v, 500w, 30amps
Kart weight: 100lbs
Rider weight: 180lbs
Also, is there a way to figure out how much the motor will take, if i reduce the gearing form 6:1 to 4:1 what's the math in figuring out if your engine/controller will be able to take it
Any help is appreciated
Thanks
Kart weight: 100lbs
Thanks
