Electric Starter For My 5.5Tecumseh OHV
klicky96
Sandusky, Ohio
Hey guys, i've been thinking about something here lately. I have a 5.5HP Tecumseh OHV Step-Shaft. I was thinking about mounting a starter to my frame with a pulley welded on it, and mounting a pulley onto my shaft right beside my clutch. Using a belt drive, i would use the wiring system I have set up to start it with a 6V Lawnmower battery. Do you think this would be a good idea?
Drew
you may need a one way bearing unless you plan to spin the starter all the time
klicky96
Sandusky, Ohio
I was thinking about using a tensioner pulley as a clutch and mounting a shift control. I could hook it up to my lights to power them and runt he starter by shifting the clutch. When i dont want my lights on, i can just disengage the pulley and ride. also, if i keep the starter going at all times, it can charge my battery also. What do you think would be the better idea? Running a clutch with the starter to my lights? or hard line my starter to my battery?
Drew
to charge your battery i would suggest use of a voltage regulator.
using your starter motor as a generator will shorten its life , but by how much i dont know. the tensioner pulley should work good geared correctly.
klicky96
Sandusky, Ohio
weight doesnt matter to me, trust me, im prretty big for my age and it gets me up the steepest hill i can find pretty quick.
karl
North east Ohio
Than whats the problem with pulling it to start?
klicky96
Sandusky, Ohio
i wanna be able to turn a key and go. like, if it stalls or something, i don't wanna keep gettin up and movin round. visualize a 7 foot long kart, my motor is 3 feet behind me. i just want a project you know?
FlatFootRacing
Speed Freak
Easley, SC
If you look into older mower startes, they were actually designed to be a starter/generator with the voltage regulator built in! a 110 John Deere is a good example! not the 70's models but the 63-67's were great mowers with a 8-10hp Tecumseh or Kohler! The starters would be plenty strong enough to get you running!
