Electric motor help
Bansil
Painter of gnomes....
So, electric guru's
I want to motorize my bead rolling machine on the cheap side, but be reliable 120v or 12v even
Kits cost $400+
YouTube diy users have used variable speed drills, garage door openers, 4-1/2 angle grinders etc as well as $!$120v motors "they just happen to have"
Yesterday I found a video where the guy was at a junk electronics store and bought 3 1974 stepper type motors
@2:09 in this video
https://www.youtube.com/watch?v=1-3nwe2dwmk
So is there something like this available? Inder say $50?
I can machine adapters etc, just low rpm so I can gear it lower, and reverse capable eould be cool, I just dont want to spend more that it cost. Doesn't need a ton of power using gearing
Thanks brains
gegcorp2012
Alabama
Couple of ideas for what its worth. I rescued some linear actuators that were on a hospital bed a few years ago that I just checked the RPMs on. They are reversable, but not variable speed unless you add a foot pedal like for a sewing machine (?). These are powerful with gear reduction but the output srill turns at 150 RPM and may need to be slowed some more.
Also, what about a 12v DC starter motor ? May be able to use a PWM controller to cut the duty cycle and make it variable speed. Not sure of the speed of a starter though.
Do you have specs for the RPM of the bead roller motor kit ?
Let me know if the 150 RPM AC motor will work and I can send you one.
Sent from my SM-J700T using Tapatalk
gegcorp2012
Alabama
I watched some YT vids and saw a couple of variable speed drill conversions. That seems to be the way to go.
They typically have a 1/2" HF drill driving a starter pinion from a car engine meshed with a flex plate mounted to the bead roller for gear reduction.
