Hi kart-builders,
I'm a student from germany. Half a year ago, I watched a video on youtube about an gokart moved by an electric forklift motor. Since then, I want to build an go kart. I am also interested in electronics and want to ride smoothly and with little noise comming from an powerful motor. I already bought the motor for this purpose. It weights nearly 40 pounds and is advised to run on 24v. I will overvolt it to either 48v or 72v which is not critical if it only drives little weight. I attached some pictures of the design I made. All parts' dimensions are real. Except for the seat which I didn't want to design correctly. http://imageshack.us/photo/my-images/51/23467625.jpg/
The kart is 160cm (63") long and roughly 120cm (47") wide. The black boxes on the sides are the lead acid batteries of course. They weight 66kg(145lbs) together. Yeah, they are heavy.
http://imageshack.us/content_round.php?page=done&l=img405/8467/42365460.jpg&via=mupload&newlp=1
I haven't designed the rear axle yet. I'm not quite sure which gear-ratio to take and I haven't yet thought about brakes. Just to give you an idea of the motor:
http://imageshack.us/content_round.php?page=done&l=img189/9080/61792706.jpg&via=mupload&newlp=1[/
Does somebody have an idea how to attach these pillow-blocks to the frame?
Here's the layout of the frame:
http://imageshack.us/photo/my-images/215/53919248.jpg/
I also kept in mind to include some steering geometry.
Camber-angle is 11° and caster-angle is 10°. I also took care of the ackermann-angle which you cannot see from this picture
http://imageshack.us/photo/my-images/202/37749406.jpg/
As you can see I want to attach the spindle-assembly not in center so that the front wheels are in line with the back wheels. Will it break when driving?
The kart will probably weight more than usual street karts. Using this motor, top speed will be more than 30mph. I'm not sure which pipe to use in this case. Any suggestions? The pipe in my design is 1" in diameter. But how thick?
