r97
Measure twice cut once
if you have choice between a golf cart motor, and a scooter motor, golf cart hands down.
Hey guys i have a 24 volt 350 watt currie motor that i took off of a schwinn electric scooter.
i have 4, 12 volt electric scooter batteries.
if i were to run the motor on 48 volts instead of 24 volts what kind of speed can i get. the motors stock rpm is 2650.
i have the motor controller which is covered in rust and im not sure if works, i have the 24volt scooter motor, the 4 12 volt batteries. which i also do not know if work because i dont have a charger for them and they have been sitting outside, and i have the powerchair motor. would it be a good idea to make the frame out of pvc pipe? or could i just use some 1 inch pipe with some 90degree elbows and such to hold it together. ( No welder)
dude just because there 'sealed" doesnt mean that they wont bust open in a crash. and even if they were "sealed" i would still want to put a nice strong steal box around them, just incase. and are you that lazy to "cover/open" box each time. what 2 small clips it that hard?
