jamyers
Next I drilled 2 holes in the frame for the fuel tank bracket so that the "right arm" of the bracket sits on the angle-iron brace I just welded in, and bolted the bracket to the frame. (PIC 1).
I was going to do some sort of additional bracing to the top of the bracket (like where it was bolted to the top of the engine), but really it's very solid as is, so I installed the fuel tank. (PIC 2).
This arrangement still has the bottom of the fuel tank and it's outlet / cutoff valve up above the kart bottom and nicely protected from anything hitting it, and the fuel line runs straight out towards the rear of the kart, right beside the engine.
Which made me want to ditch my custom fuel pump brackets on the left side of the engine, and move it back over to the right side, screwing it to the housing just above where the original pump went. (PIC 3).
I needs me a cover!
