Educate me: Mower Engine
GoDaddy
Beginner Member
I have spare mower engine laying around. It does starts. I want to try coverting to Horizontal. Before I do that, I have to understand how things works.
My lawnmower engines is either off or on(blade spinning)
When hook up to an axle, how to prevent from spinning without engine being off?
So is there a clutch I need to install? If so, please educate me on how it's installed.
You certainly do need a clutching system of one type or another. The common choice is a centrifugal clutch- it self-engages as engine RPM increases. Another choice is a CVT or continuously variable transmission, which also clutches centrifugally. A simple and cheap choice is the belt-tensioner clutch, often used on riding lawn tractors. The clutch pedal controls a lever which uses a pulley to apply tension to the drive belt, and release, too.
Got any details on that engine?
GoDaddy
Beginner Member
So with the clutch. The engine/rod would spin but will not drive the wheels until clutch/belt is tension?
. A simple and cheap choice is the belt-tensioner clutch, The clutch pedal controls a lever which uses a pulley to apply tension to the drive belt, and release, too.
I don't know, assuming it's a 2. pretty old mower.
2 or 4 stroke?
ALL engines take oil.
Let's try it this way, a multiple choice question. Do you-
a)Pour oil directly into a filler on the engine block and check the level with a dipstick?
b)Pour oil (likely tinted blue or purple) into a reservoir that is completely seperate from the engine?
c)Mix a quantity of oil (also tinted) with the gasoline before adding it to the fuel tank?
Choosing "a" indicates a four-stroke engine, while choosing "b" or "c" are indicative of a 2-stroke.
GoDaddy
Beginner Member
Sorry. This is why I titled it "educated me" :-D.
A dip stick.
LOL... Hey- as far as I am concerned, an honest question is not a stupid question. We all have to start somewhere.
Now- to be 100% fair, It might be a tad early in the game for you to attempt a vertical/horizontal conversion. There's a bit more involved than some people might let on, and can include-
-Fabricating a new manifold to mount the carb 90* to it's current orientation
-Fabrication of a conrod-mounted oil slinger
-Sealing off existing oil fill hole
-Machining the PTO shaft to accept common driveline components
-Fabrication of a stout engine mounting method
What you actually have to address may vary based on engine type and design.
GoDaddy
Beginner Member
This is also premature stage for me. As for now, my electric is not even done. I just want a heads up/ headstart so that when I'm ready I dont want to stumble.
