Easy Power Adapter For Electric Starters.
spudkilla224
Hello, I've seen engines that come with 115volt electric starters and I've come to the conclusion and have tested that using a 400 watt inverter such as this one: http://www.amazon.com/Vector-VEC-40...JP4E/ref=sr_1_6?ie=UTF8&qid=1295311324&sr=8-6
would work with a 12volt lawnmower battery. So all you'd need is a 17 dollar 12 volt lawnmower battery and an short peice of wire with a 115volt plug that plugs into the inverter thats connected to the starter plug on the electric starter actuator button. And 2 wires that plug into the inverter from the 12volt lawnmower battery.
While true, is it worth the extra weight, expense, and charging?
In my mind, there are only two benefits to electric start. 1) You can start it from a seated position, beneficial if you have reason to turn of the engine repeatedly without walking away from the kart. If you ARE walking away, a quick yank on the rope is easy enough.
2) This is the real benefit- the charging coil. Electric start engines (12 volt) have a built-in charging coil to keep the battery topped up. You can run lights and other 12 volt accessories without having to manually recharge a battery. Since a 120 volt starter-equipped engine tends not to have a charge coil, you're carrying all that extra crap and STILL have to manually recharge. Better to just remove the starter and save the weight.
However, my personal opinion aside, this may be a viable option for some. But since we're here- In your tests, what was the average AC current draw of the starters? I'm curious...
slideways
What you have to remember is if the snowblower you got the motor from has a light or not. If they don't have a light they usually have a sticker that says this engine is NOT equipped with a charging coil. I know the MTD i have at work says that. The one i have at home is a "supreme" so it has a light which would charge a battery or run a light based on rpm.
You can always add the charging coil too. Sometimes it is the flywheel itself and other times just an alternator ring bolted to the side cover with a wire coming out the shroud.
