I have.
Okay- but why? Same reason?
I have.
All you do is get the smallest drill bit you got (you don't want a huge hole), and drill right where the crack ends. You just have to be carefull it doesn't slip and scratch your windscreen. I have done it a few times. It was either that or have the crack spread and then eventually have to replace the windscreen. It does work, even though it sounds a bit crazy
Just you wait till VTNZ hear about this!
Temporary fix? and do you fill hole with slipreycon?
