Zotarajohn
I recently swapped a 5 HP Briggs for a 6 HP Tecumseh using the original clutch! From my understanding these bikes (Baja warrior) for originally came with 2.5 HP engines. Although it does free wheel when not running, as soon as you try to start it it wants to take off! I've put the bike on a milk crate so the rear wheel can freely spin and it does as soon as she fires up! But when I hit the brake it immediately stalls. The idle is down as low as possible, actually lower than any small engine that than I have ever herd! I have searched clutch and engine sections and couldn't find any problems such as mine. I did find one where the springs were just worn out! Is there a way to disassemble this clutch? I have removed the snap ring and was unable to disassemble! Do these need to be pressed on and off? This is a 420 chained w/ the opening facing the motor.it bolts to the crank shaft front (no set screws) and hooks to a jack shaft if I can open of up, can I just replace w/ new stronger springs? ! Holpeing my pics will post so you can get a better idea of what's going on here. Thanks in advance for your help. Hope I posted this correctly considering I have had problems here in the past! By the way one of the pics is of the prior Briggs engine before the swap and I know I still need a chain tensioner. Thanks again guys!
---------- Post added at 06:28 AM ---------- Previous post was at 06:22 AM ----------
Sorry the photos didn't work! Once the sun comes up I'll head out to the shop and get some more detailed pics of what I'm talking about! Again sorry guys and thanks!
