I would really like to avoid a lot of trial and error with this build, but we are building a larger version of the Grand Daddy go kart. It will have 20" rear tires, a Duromax 440 CC engine, and 40 series torque converter. I currently have a 60T sprocket planned for use with the rear wheels. So I have a 3 part question:
1) I was originally planning on installing just the stock engine and doing the mods later if I felt it needed it, but after reading some posts it seems like it makes a significant enough difference where I should just do it before installing everything. Can anyone please give me as detailed a list as possible of the necessary parts? Or where I can find more info on which parts should be replaced and how I can figure out which parts are compatible?
2) For the torque converter, I've read about replacing the springs. It seems these are color coded to indicate stiffness? How do I know which springs I should use, and are there any recommendations for the setup I specified above?
3) Regarding the sprocket tooth ratio, I believe as it currently stands I'm on the low end of the ratio. I've read that ratios of 1:6 to 1:8 should be used for 20" tires and I believe I'm currently at 1:5. I'm not positive it works this way, but the sprocket on the torque converter looks like it has 12T. Should I go with a 72T sprocket, or use a jackshaft to get a higher ratio? Or is the 60T fine?
