SquidBonez
Hi, I recently just got my project kart running but I have been having some concerns with how gas is leaking from behind the carb where the "carb insulator block" (black plastic piece behind the carb) is. I just replaced all the gaskets with new gaskets, including the float bowl o-ring. I ensured the float wasn't stuck (has happened once before and it dumped gas out of the intake) and tore down and cleaned the whole carb. Despite this it still leaks. I have circled where it is leaking from in this picture:
Note that gas only leaks when I jump on the suspension of go over bumps. The engine is mounted to the swingarm like how many off road go-karts are built, so the engine does get jostled around. Is this just some sort of carb overflow that dumps excess fuel when needed? Any suggestions?
