Problem is one of the bolts is tapered along the shaft. The threaded end is thicker for about 1 1/2" an it tapers down for the rest of the bolt. see pic-
I ended up just putting the aluminum adapter in my drill press and then drilling it out with a 1/2" bit about halfway down the hole. That would have worked if I could have got a 10mm socket around it but there wasnt enough cleareance. Getting tired of messing with it I just got out my angle grinder and went after it...
I cleaned it up the edges after this pic so its really a little better looking, but not much. But it works~~~
Another problem I have now-
If you look at the top pic, right in the center you will see a black dot. That where the choke handle/lever was at. It broke off, so I thought I will just super glue it back on. I just used a little tiny drop of superglue but it ended up glueing the choke wide open. I was able to break it back off and drill the black plastic down just a tad so that the choke is loose again. But now I have no control of the choke.
I have to take off the filter close the choke with my finger, start it up, let it run awhile, then put the filter back on. Complete pain in the donkey....
