dual engines????
Russ2251
AZUSA:Powered by LAWN-BOY
I think you may be off a couple decimal points.
It really only becomes a problem when approaching relativistic speeds.:cheers2:
Thou shalt not add my speed to the speed of light.
but its not likes its gona pull some top fuel like burnout
I'm not building a dragster.
Kenny_McCormic
Kartless....
Michigan Troll
We are talking about 2 lawn boy 2 stroke reed port engines rated for 6.5hp@3600 RPM, they are now running around double the RPM with upgraded exhaust on a ~100lb kart with narrow tires.
My 200lb manco with a little weak briggs 5hp and Carlisle 21x12-8 knobbies would push my 200lb behind back in the seat and bottom out the front suspension when I engaged the throttle, the tires would skip half a turn in dry grass and it would pull dougnuts in loose stuff. This thing will not hook up well.
find some bigger tires lol, i think this smog pump setup im making is going to make a lot of horse power maybe another 5 before the whole thing explodes lol, i think it would be safer to find two moters and gear them together
