I like karts
Rotary Power!
Just wanted to share that I'm working on making a dual carb setup for a 3hp tecumseh flathead. Yes, I know it's not the best engine to do this to, but My friend is building a go kart and this is the only engine he has available, and with a bit of tweaking, it should work well.
As for the setup, I got the idea when I looked at the stock carb on the thing and thought "wow, that's really restrictive," first off because the intake manifold bore (and carb bore as well) is micro, and because the intake charge has to flow basically 90 degrees, straight up, then another 90 degree turn to enter the intake port. With a little relocation of the gas tank, I will weld up a Y pipe straight shot into the intake, which should help flow lots. As for the carbs, I have sort of a little collection going of all sorts of small walbro carbs off of 2-strokes. The one I plan to use for the primary carb has about a 10mm bore, and the secondary I will be using (a home modded one I bored out
) is 13mm. I plan to have wire stops on both carbs, and have a little slack in between the two, so up until about half throttle, only the primary is being used, then when you really hit the gas, it pulls out the slack and opens both for a total of 23 mm of carb! (and hopefully better performance). I also am planning to de-burr the ports, and weld up a nice slightly-muffled header for it. Should turn out well. What do you think?
