Started life as a bruised, battered wreck of an old Carter "Hot bodies" kart.
I swapped out the abused 5Hp tecumseh and ancient belt centrifugal for a 346 Predator I found for $150 - brand new - and a 40 series comet clone torque converter. Switched the stock 10T final drive sprocket to a 17T.
The speed and torque were where I wanted them. But with the added momentum the suspension, or complete lack-there-of, became a problem.
I welded up some spring loaded spindles, and cocked the wheels out just a hair so they'd dig in on turns. And while I was working over the front end I toed the wheels in a degree or two. (1/8th or 1/16th of an inch closer measure on front than back) Also dropped the ambient pressure in the rear wheels from 15lbs to about 8lbs.
Had steering issues at 1/2 throttle and up because of how light the front is, and how much weight sits on the live axle. So I welded up a bumper. Gives my front workings a bit of crash insurance, and the handling improved noticeably.
Also raised the steering wheel about 7" to comfortably accommodate a 250lb 6ft adult.
Stats:
35Mph, kicks up fountains of dirt and grass from a standstill, and will do donuts till the sun goes down. Let off for a second, crack the steering wheel, and stomp the throttle at full speed, and it kicks into a smooth arc.
I like to leave governors intact. I'm superstitious about removing the longevity devices the factory thought were necessary... but! If I reach back and pull the linkage, I can reach about 43-44Mph. And that's with little 6" tires.
What's next? Probably a rear-end rework. 1" axle to replace the 3/4 one. I have some 22x11 knobby tires laying around and a whole 1" rear-end [sprocket, brake, and 4on4 hubs]. I work as a service tech on industrial doors and dock equipment for Overhead Door, so I have access to shafts and sprockets of just about any kind. But I'm pretty happy with it as it is now.
Time to move onto another project! I'll leave this one in running condition so I have something to have fun on while I build the next little monster.
Stats:
